inter vlan configure
Oct 21st, 2008
hi expert
i want to configure inter vlan configure in 3550 switch.i had configure but not working could you guide me to configure it
arupbiet2006 Tue, 10/21/2008 - 22:16
hi Istvan
thnx for your reply but this switch is client end i can't access it...
i hda configure
* f0/1 is trunk port
*f0/2,f0/3,f0/4 ,f0/5 switch port access vlan 1,vlan 2,vlan 3,vlan 4,vlan 5
*each vlan assign different ip address
vlan 1-
vlan 2-
vlan 3-
vlan 4-
vlan 5-
*and i rout gateway)
Istvan_Rabai Tue, 10/21/2008 - 22:23
Hi Arup,
I don't quite understand how you want to configure it if you can't access it.
If you have access to it, use the "show ip route" command to check if you have the routing table.
If you don't have the routing table, you should enable ip routing using the "ip routing" global config command.
arupbiet2006 Tue, 10/21/2008 - 22:31
i had configured ip route gateway)
itdsmartnet Tue, 10/21/2008 - 23:22
hi, you have to configure SVI ports in order for intervlan routing worked in 3550. for this you have to assign ip address to every vlan interface. e.g interface vlan 1
ip address w.x.y.z subnet mask
interface vlan 2
ip address a.b.c.d subnet mask
Istvan_Rabai Tue, 10/21/2008 - 23:30
Hi Arup,
Is routing working now between the vlans?
If not, please post the output of "show ip route" command.
