10-21-2008 10:29 PM - edited 03-11-2019 07:00 AM
How to enable Multicasting in FWSM Multiple Contex Mode ?I have read & checked Multiple context mode doesnt support the IGMP command.Could you please let me know how to enable multicast ..?
Thanks in advance
10-22-2008 04:57 PM
Hi Manik,
As you mentioned, multicast is not supported on a multi-context FWSM. This is documented in the configuration guide:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/contxt_f.html#wp1116132
Hope that helps.
-Mike
10-22-2008 05:27 PM
Manik,
As Mike mentioned you cannot do Multicast Routing in Multiple Context Mode. But, you can bridge the multicast packets in Multiple Context Mode by making the context a L2 Firewall.
Multicast bridging is supported
Arul
*Pls rate if it helps*
