inter vlan configure in 3550 switch
Oct 21st, 2008
i had configured like this...........
CAT3550# show running-config
Building configuration...
interface Vlan1
ip address 10.10.10.1 255.255.255.0
interface Vlan2
ip address 20.20.20.1 255.255.255.0
ip policy route-map pbr
interface Vlan3
ip address 30.30.30.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip classless
ip http server
access-list 10 permit 20.20.20.0 0.0.0.255
route-map pbr permit 10
match ip address 10
set ip next-hop 30.30.30.2
Istvan_Rabai Tue, 10/21/2008 - 23:36
  • Gold, 750 points or more
Hi Arup,
With this configuration, any packet that is coming into the switch from the 20.20.20.0/24 subnet (vlan2), will be sent out to next hop 30.30.30.2 through interface vlan3.
Is this what you want?
Istvan
arupbiet2006 Tue, 10/21/2008 - 23:48
Istvan
just i want vlan 2 will admin vlan which will access all vlan .how i can do it
Istvan_Rabai Tue, 10/21/2008 - 23:57
Hi Arup,
From interface vlan2 remove the "ip policy route-map" command.
This way vlan2 will access all other vlans within this switch, supposed ip routing is enabled.
Cheers:
Istvan
arupbiet2006 Wed, 10/22/2008 - 00:07
hi Istvan....
changed it but still not working...
configure like this....
interface Vlan1
interface Vlan2
interface Vlan3
ip classless
ip http server
end
have you any configure which is my desire
Istvan_Rabai Wed, 10/22/2008 - 00:13
Hi Arul,
Please remove "ip policy route-map" from vlan2.
The commands for this are
conf t
interface vlan2
no ip policy route-map pbr
Also, please enable ip routing:
conf t
ip routing
Cheers:
Istvan
