Policy based routing catalyst 3750
Answered Question
Oct 21st, 2008
When I want to configure policy based routing. When i want activated it on a vlan interface it won't work.
I don't have the option ip policy route-map
The command policy is not known...
Equipment i'm using is Catalyst 3750. Ios ipbase 12.2(25)SEE4
Best regards
Jorg
Correct Answer by alan.blake about 8 years 4 months ago
whoops.
Correct Answer by Jon Marshall about 8 years 5 months ago
Jorg
You need to be running the right SDM template on the switch as there are a different number of possible templates. From memory i believe it is the routing template you need. See attached link for template details -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sec/configuration/guide/swsdm.html
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 10/21/2008 - 23:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jorg
Jon
jorg.ramakers Wed, 10/29/2008 - 02:50
Hi Jon,
Thanx for the tip. You need indeed enable pbr by the template and it is necessary to run at least ipservices instead of ipbase.
Tnx
Jorg
