PIX 525 Ping configuration
Oct 21st, 2008
I have cisco PIX 525 with OS 6.3.
I want to connect a pc directly to the pix inside interface and ping outside interface of pix from that PC.
can anyone post the configuration for it.
Early response would be highly appreciated
Thanks in advance.
Jon Marshall Tue, 10/21/2008 - 23:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You can't do this on a pix running this version of code. From the PC you connected to the inside interface you can ping the pix inside interface and you can ping hosts reachable via the outside interface of the pix ie. you can ping thru the pix. But you can't ping the outside interface from the inside.
Jon
