3640 Xmodem Problem
newnetman
Hello All,
In an attempt to install a 3640 series i encountered the following which hampered the installation, any help how how to go about it?.
Do not start the sending program yet...
File size Checksum File name
32031472 bytes (0x1e8c2f0) 0xd51f c3640-js-mz.124-13b (bad checksum: 0x37b9)
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c3640-jk9s-mz.124-16 ...
BB0
ERR:Image size exceeds free flash space
rommon 3 >
How can i make space available for the installation if that is the problem?.
Thanking you all in advance,
andrew.prince
Level 10
Level 10
Looks like to need to remove any files for images from the flash, before you can copy the new image into it.
HTH>
Many thanks for your response. But if at all i have to remove any file from the flash, which is it and how do i go about it?
Follow the below instructions - there is an option to erase the flash before the xmodem copy takes place.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008009433b.shtml
HTH>
Sorry the link you sent does not contain solution to my problem. thanks any way.
