nat order of operation on a PIX 6.3 or higher
Oct 22nd, 2008
Hi folks,
whats the order of operation when it nats, acl and routes.
When it comes to routing are you routing the pre-nat address or the nat'd address?
Anything to clear it up would be appreciated. Does it work the same way as the router?
Cheers
Tony
abinjola Wed, 10/22/2008 - 04:22
  • Cisco Employee,
Here is the order :-
1. Recieve Packet.
2. Existing Connection?
3. Permit by Inbound ACL on interface?
4. Match translation rule (nat, static).
5. NAT embedded IP and perform security checks / randomize sequence number.
6. NAT IP header.
7. Pass packet to outgoing interface.
8. Layer 3 route lookup?
9. Layer 2 next hop?
10. Transmit packet.
hope it helps !
