IP NetManager v1.1 Event logs
Oct 22nd, 2008
We tried unsuccessfully to find the way to clear or delete event logs from database on IP Netmanager v1.1. We succeed to acknowledge but not to delete logs.
Thanks in advance
mchin345 Wed, 10/29/2008 - 15:21
  • Silver, 250 points or more
From Reports > System > SNMP Trap log, you can see all of the traps the system has received. A trap is translated to an event only if the device is managed and the trap is supported. Usually, when the system receives active monitor events such as Ping Down or SNMP Down, it stops receiving other events for that device.
Cleared events that are removed from the event report can be found in the Event History report
For further information click this link.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_netmanager/1.1_data/faq/troubleshoot.html#wp54759
acharyr123 Sun, 11/08/2009 - 06:53
Hi Friend,
I am facing 2 critical problems in Netmanager 1.1
1. Whenever i discover Call Manager it gets discovered as Host as the capability, where as it should show as Call Manager. How to rectify this issue...
2. After acknowledgning the events, still it shows as RED which is painful.
Can you kindly give me some clue on how to resolve these issues.
Rgds,
Partha
