Error init: ID "SD0" respawning too fast: disabled for 5 minutes. on CUCM6.
arani
Hi all
after a fresh install of CUCM 6.1.2, we receive the following console error:
Hardware is MCS-7835 IBMX345.
Ideas?
Best regards.
jsivulka
Level 5
Level 5
Try this bug CSCsq07030 & CSCsj74466. INIT: Id "SD0" respawning too fast: disabled for 5 min Error on CUP...
Hi all
I have solved the problem by myself enabling the com port(RS232) at bios level.
The com port will be used for console connections.
Hi Arani,
I have been facing the same problem..
If enabling the com port has worked for you, probably it would work for me as well.
Can u elaborate how did u enable it, as am not Linux geek.
Thanx in advance!!
Dinesh
