LMS 2.6 / upgrade to RME 4.0.6 : config issue and device update issue
Oct 22nd, 2008
Since customer has update RME 4.0.6. He has many devices which config failed partially with this message:
Protocol ==> Unknown / Not Applicable
CM0056 Config fetch failed for Amberieu Cause: CM0204 Could not create DeviceContext for 653 Cause: CM0206 Could not get the config transport implementation for 10.44.137.5 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
So he tried to install 2960 package, but it failed.
Now when he select in Device update RME or device type count number we have this error: see attach file error.txt
I tried to delete package 2960 but it failed, I saw in psu.log that the file didn't exist on disk: [ Wed Oct 22 16:12:10 CEST 2008 ] ERROR [PackageInstaller : LogAndUpdateEvent] : Package installation failed : Reason :[java.lang.Exception: Delete failed for d:\cwlms\cscopx/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs/Cat2960.zip]
[ Wed Oct 22 16:12:11 CEST 2008 ] ERROR [PackageManager : unInstallPackages] : Exception while uninstalling: nulljava.lang.NullPointerException
at com.cisco.nm.xms.psu.packagemgmt.PackageInstaller.LogAndUpdateEvent(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.PackageInstaller.invokeUninstallForPackage(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.PackageInstaller.performUninstall(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.PackageInstaller.autoUnInstall(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.PackageManager.unInstallPackages(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.InstallWrapper.unInstallPkgs(Unknown Source)
at com.cisco.nm.xms.psu.packagemgmt.InstallWrapper.main(Unknown Source)
[ Wed Oct 22 16:12:11 CEST 2008 ] ERROR [CreateMaps : retainEntries] : String index out of range: -1
Packages are list on device update for delete purpose but they don't exist on disk.
Any idea ? Thanks, Elisabeth
Joe Clarke Wed, 10/22/2008 - 09:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Looks like you have a few problems. All point to an issue with the RME 4.0.6 installation. Please post the list of contents in both d:\cwlms\cscopx/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and D:\cwlms\cscopx\www/classpath/com/cisco/nm/xms/psu/pkgs/rme. Also, please post the RME map files under D:\cwlms\cscopx\www/classpath/com/cisco/nm/xms/psu/maps.
Joe Clarke Fri, 10/24/2008 - 11:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
First, your RME package directory does not match your PSU package directory. This is bad. There are five packages known to PSU, but not being used by RME. You should shutdown CiscoWorks Daemon Manager, then copy the five missing packages from the PSU directory to the RME lib/pkgs directory. Then restart Daemon Manager.
Second, I actually wanted to see the RME package map files.
ebezombes Mon, 11/03/2008 - 08:26
I stoped process.
I copied files from psu to lib:
AS5350.zip
AS5400.zip
ASA.zip
Cat2960.zip
Cat3550.zip
Cat3560.zip
Cat3750.zip
Cat6000.zip
Cat6000IOS.zip
CatGL3.zip
CBS3000.zip
CE500.zip
MDS.zip
MetroSwitch.zip
NAM.zip
Pix.zip
Rtr12000.zip
Rtr2800.zip
Rtr3200.zip
Rtr7000.zip
Sfs.zip
I started process, I have same issue when I selected in Device update RME or device type count number.
Here you can find files :
- rmeDeviceMap.map
- rmePackageMap.map
It seems corrupt, isn't it ?
Joe Clarke Mon, 11/03/2008 - 10:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes. This is known bug CSCsj58812:
Symptom:
The package and device map files used the the Product Support Updater may become corrupt. This corruption can lead to Java exceptions when trying to view package information under Common Services > Software Center > Device Update. One possible exception is:
java.util.NoSuchElementException
at java.util.StringTokenizer.nextToken(StringTokenizer.java:259)
at com.cisco.nm.xms.psu.ui.gui.model.action.DevUpdate.getPackageMap(Unknown Source)
at com.cisco.nm.xms.psu.ui.gui.model.action.DevUpdate.perform(Unknown Source)
Conditions:
This can occur if multiple PSU jobs are started before one job has had a chance to properly complete.
Workaround:
Before executing any other PSU jobs, wait for the CiscoWorks daemons to recycle, and fully restart.
If the maps become corrupt, run the following commands to regenerate the files. For Windows (each command is on ONE LINE):
set NMSROOT=%CWMIBDIR%\..\..\..
%NMSROOT%\lib\jre\bin\java -classpath %NMSROOT%\lib\jre\lib;%NMSROOT%\lib\classpath;%NMSROOT%\objects\log4j\1.1.3\log4j.jar;%NMSROOT%\MDC\tomcat\shared\lib\MICE.jar;%NMSROOT%\MDC\tomcat\shared\lib\NATIVE.jar;%NMSROOT%\MDC\tomcat\shared\lib\jdom.jar;%NMSROOT%\www\classpath;%NMSROOT%\lib\classpath\servlet.jar;%NMSROOT%\MDC\tomcat\webapps\cwhp\WEB-INF\classes com.cisco.nm.xms.psu.packagemgmt.map.CreateMaps %NMSROOT%\www\classpath\com\cisco\nm\xms\psu\pkgs\rme
%NMSROOT%\lib\jre\bin\java -classpath %NMSROOT%\lib\jre\lib;%NMSROOT%\lib\classpath;%NMSROOT%\objects\log4j\1.1.3\log4j.jar;%NMSROOT%\MDC\tomcat\shared\lib\MICE.jar;%NMSROOT%\MDC\tomcat\shared\lib\NATIVE.jar;%NMSROOT%\MDC\tomcat\shared\lib\jdom.jar;%NMSROOT%\www\classpath;%NMSROOT%\lib\classpath\servlet.jar;%NMSROOT%\MDC\tomcat\webapps\cwhp\WEB-INF\classes com.cisco.nm.xms.psu.packagemgmt.map.CreateMaps %NMSROOT%\www\classpath\com\cisco\nm\xms\psu\pkgs\cvw
For Solaris:
env LD_LIBRARY_PATH=/opt/CSCOpx/lib:/opt/CSCOpx/MDC/lib /opt/CSCOpx/lib/jre/bin/java -classpath /opt/CSCOpx/lib/jre/lib:/opt/CSCOpx/lib/classpath:/opt/CSCOpx/objects/log4j/1.1.3/log4j.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/MICE.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/NATIVE.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/jdom.jar:/opt/CSCOpx/www/classpath:/opt/CSCOpx/lib/classpath/servlet.jar:/opt/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/classes com.cisco.nm.xms.psu.packagemgmt.map.CreateMaps /opt/CSCOpx/www/classpath/com/cisco/nm/xms/psu/pkgs/rme
env LD_LIBRARY_PATH=/opt/CSCOpx/lib:/opt/CSCOpx/MDC/lib /opt/CSCOpx/lib/jre/bin/java -classpath /opt/CSCOpx/lib/jre/lib:/opt/CSCOpx/lib/classpath:/opt/CSCOpx/objects/log4j/1.1.3/log4j.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/MICE.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/NATIVE.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/jdom.jar:/opt/CSCOpx/www/classpath:/opt/CSCOpx/lib/classpath/servlet.jar:/opt/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/classes com.cisco.nm.xms.psu.packagemgmt.map.CreateMaps /opt/CSCOpx/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw
ebezombes Tue, 11/04/2008 - 12:07
Thanks for your update
I made the command line, I had this message:
log4j:ERROR Please initialize the log4j system properly
=> I saw in forum, that was a cosmetic error message.
Unfortunaly, I saw corruption on rme map file, I deleted lines which seem to be bad.
=> Now I can select in Device update RME or device type count number.
Now I try to install cat2960 package and I have this message:
Consistency check failed for base package SharedCdaIOS
Thanks, Elisabeth
Joe Clarke Tue, 11/04/2008 - 12:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The map files may still not be consistent. Move the RME map files out of the way, then run the RME command again. These map files must be properly generated.
This may or may not fix the Cat2960 installation problem. The error points to an older version of SharedCdaIOS being installed than what is required. Given that you had package problems to begin with, you may need to reinstall RME from scratch to fully resolve all of these problems. You must have SharedCdaIOS 1.0.1 installed.
ebezombes Wed, 11/05/2008 - 02:08
I suppress both rme map files and executed commands, now files are ok.
But 2960 package installation failed.
I reinstalled RME 4.0.6 and now I could install 2960 package. :)
Thanks, Elisabeth
