Richard Burts Wed, 10/22/2008 - 09:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Juan
I do not have direct personal experience with this, so I checked the Feature Navigator on CCO. It indicates that with the IP PLUS or with Enterprise Plus feature sets that DLSW+ is supported on the 4500.
Rick
juanluis@ingenia.es Wed, 10/22/2008 - 10:10
Thanks a lot. DO you mean that there is a ios i mage for the 4500 and sup V that support DLSW and bridge?
I have enter in the web but I dont find anything as you say. Could you send me the url, please?.
I need to confirm that this feature is avalaible, so I could open a case and ask the ios to cisco.
If you answer yes to my first question I will be a very happy man!
Juan Luis.
Richard Burts Wed, 10/22/2008 - 10:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Juan Luis
What I find is not specific about the Sup V. But the feature navigator does say that this image c4500-js-mz.122-23.bin does have support for bridging between 802.1Q VLANs and does have support for DLSW+.
You can use the feature navigator at this URL:
www.cisco.com/go/fn
and it has options to check by feature, by platform, or by spacific image.
Rick
juanluis@ingenia.es Thu, 10/23/2008 - 00:54
Are you sure this is for Catalyst 4500 with supervisor V?
In the feature navigator I don't find anything about your version for the catalyst 4500.
Richard Burts Thu, 10/23/2008 - 07:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Juan Luis
Are you saying that you went to the Feature Navigator (at www.cisco.com/g/fn), that you selected the option to search for a particular release, that you specified image c4500-js-mz.122-23.bin and that it could not find this image?
Rick
juanluis@ingenia.es Thu, 10/23/2008 - 07:54
Yes,
When I search a release selecting the Catalyst 4500 and sup V I dont find the file you say.
The file c4500-js-mz.122-23.bin is for Catalyst 4500 sup V or it is for router 4500?
If it is for catalyst, how or where can I get it?
Juan Luis.
Richard Burts Thu, 10/23/2008 - 08:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Juan Luis
It appears that this image is indeed for the router 4500. my mistake. I appologize. Based on this I was incorrect to say that there was support for DLSW in the Cat4500. Having looked again I believe that DLSW is not supported on this platform.
Sorry
Rick
juanluis@ingenia.es Thu, 10/23/2008 - 09:43
No problem
Thank you very much. I will use a external router to run dlsw.
I have 2 4506 and 2 routers and must work redundant, if it is not very umpleasant for you, I would like send you the configs so you can take a look and tell me if there is any mistake. You seem to know very much about this.
Thanks for all.
Juan Luis.
Richard Burts Thu, 10/23/2008 - 09:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Juan Luis
If you send the configs I will take a look at them.
Rick
