RSPAN configuration
Oct 22nd, 2008
Hi Guys,
I have 4 6500 switch and have layer 2 etherchannle with STP running across them.
6500-1-------6500-2
6500-3------6500-4
I have various servers connected to all 4 switches. now i want to monitor the traffic between those servers. I plan to use VLAN based RSPAN so that I can connect Sniffer(dedicated) only one switch.
But i see one limitaiton of RSPAN that one of the switch where Sniffer is connected (i.e destination port)i also have source ports/vlan.. Will that allow me to do ?
If not, what is best way to have monitoring for above requirment....
Thanks in advance,
Chintan
rickegge1 Wed, 10/22/2008 - 10:26
You can have multiple RSPAN sessions on the 6500 series.
Ex.
Monitor Session 10 Source Remove Vlan 890
Monitor Session 10 Destination Interface Gig1/1
Monitor Session 20 Source Interface Gig1/2
Monitor Session 20 Destination Remote Vlan 890
Monitor Session 30 Source Interface Gig1/3
Monitor Session 30 Destination Remove Vlan 890
On the switch with the Sniffer connected you will need session 10, on all switches session 20/30 are all you will need to do to send traffic to the sniffer.
Mo'ath Al Rawashdeh Fri, 10/24/2008 - 02:32
  • Bronze, 100 points or more
you mean that on the switch where the sniffer is to be connected, it has the destination port and some source ports and vlans?
I don't think its going to be an issue to you as you are allowed to do this via RSPAN.
Cheers to all.
