VMWare ESX and portfast
Answered Question
Oct 22nd, 2008
Is there any downside at all to enabling portfast on an ESX server? Do I have to worry about vSwitch creating loops or any other reason that would cause a loop doing this? It is a end host after all.
John
Correct Answer by francisco_1 about 8 years 4 months ago
i dont think so. as far i as know you need to enable portfast on the interface to prevent any connectivity issue. you dont want your ESX server taking part in spanning-tree transtion process so with portfast the port the ESX server is connecting to will transtion to forwarding state.
good doc http://www.cisco.com/univercd/cc/td/doc/solution/vmware.pdf
Overall Rating: 5 (1 ratings)
Correct Answer
francisco_1 Wed, 10/22/2008 - 08:53
