Dial Plan
Oct 22nd, 2008
I would like to be able to dial a three digit access code to reach an Avaya Paging System. When I create Route Pattern 776 in call manager I get " Your call can not be completed"
Since we use four digit dialing here, is there a way to create a dial plan for three digits that would strip off the fourth digit? If so how do you do this?
Thank You
Jaime Valencia Wed, 10/22/2008 - 09:26
  • Cisco Employee,
  • Hall of Fame,
    2011
have you already checked the CSS and partitions??? it shouldn't be a problem to dial only 3 digits in a 4 digit dial plan.
at most you would get interdigit timeout if overlapping
java
if this helps, please rate
Mojo1 Wed, 10/22/2008 - 09:38
I changed the partition to a local partion. That partition is within the calling search space as a Selected Partition.
Now I get a busy signal instead of the message I got last time.
