ACE SSL Key & Certificate rules
Answered Question
Oct 22nd, 2008
hi,
- Is it necessary that every CSR (different common names) use/generate a unique key or a single key can be used for multiple CSRs (i.e. different common names).
Correct Answer by Syed Iftekhar Ahmed about 8 years 6 months ago
I dont see why it shouldn't work but its definitely not recommended and is not a good idea.
From Carlisle Adams' PKI book, recommending against putting the same key
in multiple certs:
"It is too easy to "slip up" and not hold all other important aspects of
these multiple certificates constant. [...] If a single public key is
contained in multiple certificates and the private key is compromised (or
other circumstances occur that require revocation), it must be "remembered"
(or discovered) which certificates contain this key so that they may all be
revoked. [...] Having the same public key in multiple certificates can
complicate the administrative processes involved in certificate management."
http://www.amazon.com/exec/obidos/ASIN/0672323915/104-7451273-2110334
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 10/22/2008 - 11:25
  • Blue, 1500 points or more
in multiple certs:
Syed Iftekhar Ahmed
dan.stith Wed, 11/05/2008 - 10:15
Always use a unique key per CSR. while it it technically possible the prior poster gave many of the reasons why it is a bad idea and there are many others. Just assume a key pair is unique to a CSR.
