Access or Trunk question?
Answered Question
Oct 22nd, 2008
Just wondering if there is ever a scenario where two switches connected to one another should not be trunked?
For example I have switch A connected to Switch B
Switch A config:
interface GigabitEthernet1/1
switchport
switchport access vlan 100
switchport mode access
Switch B config:
Think of Switch A has the hub with various switches spoked off of it all connecting as a different vlan. (100, 101,102 etc...)
it just doesn't make sense to me why it was configured this way. I would think the interfaces between the switches should be trunked? However, only a single vlan is passed so is it necessary?
Correct Answer by Jon Marshall about 8 years 4 months ago
If you only need 1 vlan on each switch then there is no reason to use a trunk link and it is perfectly valid to just use a switchport access configuration.
However gererally speaking you would want to have at least 2 vlans on each switch one for data and the other for management. You don't have to a separate management vlan but it is recommended best practice.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 10/22/2008 - 11:30
Jon
