OSPF CE to PE default route
Oct 22nd, 2008
Is there a way to propagate default route from CE router with cmd "default-information originate always" across mpls cloud to the other side CE in same mpls vpn instance?
I know this can be done via static route/redistribute under bgp af/default-information originate under bgp af on PE. Is this the only way?
thanks,
Branko
Overall Rating: 5 (1 ratings)
devang_etcom Thu, 10/23/2008 - 06:35
  • Gold, 750 points or more
I guess yes that the only way!!! but you can have GRE tunnel between two different sites and run the OSPF between them so DEFAULT route originated at one end will propagate to all OSPF domain via tunnel interface.
regards
Devang Patel
bmlakar Mon, 10/27/2008 - 06:27
Hi Patel,
Thanks for your reply and your useful suggestion.
kind regards,
Branko Mlakar
guruprasadr Tue, 10/28/2008 - 03:02
HI Branko, [Pls RATE if HELPS]
The best option is,
Enable the LAST MILE BGP at the HO side, advertise the DEFAULT (0.0.0.0) towards the Provider Edge.
Since, the Service subscribed is MPLS-VPN, the DEFAULT Route is visible in the entire MP-BGP Mesh of Service Provider Cloud.
By this way, the SPOKE Location will be able to access the DEFAULT in order to reach the HO side.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
