IOS FW and router
Answered Question
Oct 22nd, 2008
What is the difference between an IOS FW and a router ? Can they be used interchangebly ?
Correct Answer by ajagadee about 8 years 5 days ago
The below Q&A on IOS Firewall should help answer most of your questions.
*Pls rate if it helps*
Overall Rating: 4.5 (2 ratings)
Jon Marshall Wed, 10/22/2008 - 12:50
Not sure exactly what you mean by IOS FW. There is a firewall called CBAC (Content Based Access Control) which runs only on Cisco routers. It is a fully stateful firewall.
CBAC is part of the advanced security feature set that can be run on IOS routers.
