tunnel and acl
c-drozd
VPN Parameters site to site vpn
pix remote end point is XXX.XXX.80.108
pix remote network is 192.168.50.0/24
pix will need to make ACL from 172.24.176.9 to host 192.168.50.83 and 192.168.50.86
pix will need to NAT intresting traffic to 172.24.176.0 /24
pix remote
Phase 1
Authentication: Pre-Shared
Encryption: 3DES
Hash: SHA
DH: 1
Lifetime: 86400 sec
Phase 2
ESP encryption 3DES
ESP authentication
Lifetime 28800
I tried different acl configureation and I still have problems creating a tunnel.
I attached the configuration of local pix
Hello Casey,
Two things; first, as Arul mentioned, you already exempt the translation and it never reaches your policy nat. Second, although you remove that exempt statement, traffic will flow through nat&global #1 first since you specified 0.0.0.0 0.0.0.0 and it wont reach nat&global #5 which is your policy nat. Here is my recommendation
no nat (inside) 0 access-list nonat
no access-list nonat permit ip 192.168.0.0 255.255.255.0 172.24.176.0 255.255.255.0
no access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.50.0 255.255.255.0
no nat (inside) 5 access-list policynat 0 0
no global (outside) 5 172.24.176.9
nat (inside) 5 0 0
global (outside) 5 interface
no nat (inside) 1 0 0
no global (outside) 1 interface
nat (inside) 1 access-list policynat
global (outside) 1 172.24.176.9
5 Replies 5
ajagadee
Casey,
If you are NATTing and then encrypting the traffic, you really dont need NONAT Command.
Is it possible to remove the below line from the configuration and try to bring up the tunnel.
Arul
*Pls rate if it helps*
Hello Casey,
nat (inside) 5 0 0
Will the local pix able to access the internet for email etc?
Casey,
Yes, because all your internal traffic destined to internet will get NATTed to the outside interface and get routed accordingly.
Arul
c-drozd
The tunnel work no problems accept the tech folks left me this email.
I'm attempting to ping your NAT'd IP address and this is unreachable on our end. Please be sure that your security device allows traffic initiated from us as well.
