10-22-2008 04:07 PM - edited 03-15-2019 02:07 PM
Howdy,
Is it possible to add a zero prefix to the callerid on an inbound call to a 5300 gateway?
Telco wont add it so we need to.
Any thoughts?
Solved! Go to Solution.
10-23-2008 06:36 AM
but you need to modify the inbound calls, so why did you configured an outbound calling number?
translation rules can certainly do this but you need to configure this in the right direction
java
if this helps, please rate
10-22-2008 05:51 PM
yes, look at this doc:
Add Prefix to the Missed Call Number
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
java
10-22-2008 07:29 PM
Unfortunately we arent using a call manager but a softswitch to terminate these calls.
I've tried putting the translate-outbound calling number translation rule on the voip peer but it still doesnt change the ani.
Any other ideas?
10-23-2008 06:36 AM
java
10-23-2008 12:51 PM
Thanks had it pointing the wrong way. Changed and now working.
Many thanks
