Does Cisco VPN client support DES for remote VPN to a PIX 501 ?
Answered Question
Oct 22nd, 2008
Hi netpros,
I am trying to set up a remote vpn using Cisco VPN client 5.0 (I have also tried version 4.6) and a PIX501 with DES support ONLY. By looking at the logs on the PIX, I can see the client attempting to negotiate phase 1. It only sends 9 attempts (neither of them using DES as encryption) and it stops there and the VPN can't be completed. I expected the vpn client to keep on trying until a match is found. Are there any limitations on this set up.
Your comments are much appreciated !!!
Correct Answer by ajagadee about 8 years 2 days ago
Hello Fernando,
Interesting Observation. Are you using DES with SHA or DES with MD5. From what I can see in the below URL, DES with MD5 is a supported IKE Proposal.
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
