ASA5520 readonly admin for adsm
Oct 22nd, 2008
Greeting
I am trying to create a readonly user who can access ASA5520 by using ADSM client.
However, it is not working as I expected. my ASA5520 has more than one contents, but, the readonly user can only see the first content, not the rest.
Could I get some advice on these? do I need create same user accounts on every content? do I need set AAA feature for every content also?
Any comments will be appreciated
Thanks in advance
Anonymous (not verified) Wed, 10/29/2008 - 08:53
The Authorization tab lets you control access per user after you authenticate with a valid username and password. You can configure the security appliance to authorize management commands.
The Predefined User Account Privileges Setup pane displays a list of commands and privileges ASDM issues to the security appliance if you click Yes. Yes allows ASDM to support the three privilege levels: Admin, Read Only and Monitor Only.
Refer the below URL to set ASA5520 for read only mode:
http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/user/guide/devaccss.html#wp1218050
