intervlan communication in 3650 switch
Oct 22nd, 2008
how i can configure like this type of vlan communication...
vlan10 communicate only vlan20 ,vla30,vlan40,vlan50 but vlan 20,vlan30,vlan40,vlan 50 not communicate each other .
Overall Rating: 2 (1 ratings)
arupbiet2006 Wed, 10/22/2008 - 23:56
hi sir,
already i had configure access list vlan10 access vlan20(ip),vlan30(ip).vlan40(ip) ,vlan50(ip)...but still it not working and also not access internet by indivisual vlan..
kindly help me how i can do this task
arupbiet2006 Thu, 10/23/2008 - 00:19
Switch(config)#interface vlan 10
% Unrecognized command
mfreijser Thu, 10/23/2008 - 03:43
All the information you need about the commands is in the Configuration Guide as specified above.
About your last question: Try the "ip access-group..." interface configuration command if you want to connect a access-list to a interface. playing around with the questionmark (?) will certainly help you on your way!
