VPN Concentrator reboots
Oct 23rd, 2008
VPN concentrator 3000 just reboots randomly. I get this error on syslog:
Failed signature check on buffer free. Ptr=01edb800, CPC1=00761d70, CPC2=0001a9b8
Richard Burts Thu, 10/23/2008 - 09:11
Keith
I am not familiar with that particular error. But it sure seems to indicate that you are hitting a problem in the software running on the concentrator. I would suggest upgrading the version of code (or perhaps opening a case with TAC if the concentrator is under a maintenance plan).
Rick
