Can't disable DCR debugging
Oct 23rd, 2008
After debugging the Device and Credentials Repository, I disabled the corresponding debug mode in CS Log Configuration and I also tried out the "reset all"-button. But the dcrclient.log-file is still growing fast and filled up with debug-messages. Is there any other way to disable debugging ?
We are using LMS 3.1.0, CS 3.2.0 on Solaris.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 10/23/2008 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Debugging can be manually disabled by modifying /opt/CSCOpx/lib/classpath/com/cisco/nm/dcr/log4j-dcrclient.properties, and changing all instances of DEBUG to FATAL. Then, you need to restart dmgtd.
s.leyer Mon, 10/27/2008 - 04:32
Hello JC,
good advice. Debugging is off.
Silvia
mladenp Fri, 10/14/2011 - 00:40
Hello Joe,
I have same problem on LMS 3.2.1. But I have two versions of that file log4j-dcrclient.properties and log4j-dcrclient1.properties. Files are slightly different, but there isn't DEBUG in both files.
log4j-dcrclient.properties:
############# LOG file details ##############################
log4j.appender.A-client1=org.apache.log4j.FileAppender
log4j.appender.A-client1.File=\\log\\dcrclient.log
log4j.appender.A-client1.Append=true
log4j.appender.A-client1.layout=org.apache.log4j.TTCCLayout
log4j.appender.A-client1.layout.DateFormat=[ EEE MMM dd HH:mm:ss z yyyy ]
##### These are DCR files  ###########################################################
log4j.category.com.cisco.nm.dcr=FATAL, A-client1
##### DCR file list end  ##############################################################
#### CTM File list ####################################################
log4j.category.CTM=FATAL,  A-client1
log4j.category.CTM.server=FATAL,  A-client1
log4j.category.CTM.client=FATAL,  A-client1
log4j.category.CTM.Registry=FATAL,  A-client1
log4j.category.CTM.common=FATAL,  A-client1
log4j.category.com.cisco.nm.xms.ctm=FATAL, A-client1
#### CTM File list end ################################################
#Setting Additivity
log4j.additivity.com.cisco.nm.dcr=false
log4j.additivity.CTM=false
log4j.additivity.CTM.server=false
log4j.additivity.CTM.client=false
log4j.additivity.CTM.Registry=false
log4j.additivity.CTM.common=false
log4j.additivity.com.cisco.nm.xms.ctm=false
log4j.appender.A-client1.File=D:\\CSCOpx\\log\\dcrclient.log
And log4j-dcrclient1.properties:
#Setting Additivity
Mladen
