Warning message
IPSEC VPN on Metro-E connection
Answered Question
Oct 23rd, 2008
Hi all,
I have a quick question. Is it possible to run L2L IPSEC VPN via a Metro-E connection? It doesn't make sense to do something like that via Metro-E but this connection is with a partner therefore on both ends, firewalls are in place. WIth port forwading, NATting, etc,etc, I ran into problems to provide additional services because of that. I am hoping a L2L IPSEC VPN on both ends will solve this problem once and for all. The only question is to be sure in fact a Metro-E is just a ethernet connection and really no difference from setting up a L2L IPSEC VPN via the internet.
Thank you for your help.
Correct Answer by ajagadee about 8 years 10 months ago
Eric,
Yes, L2L IPSEC VPN Tunnel Over Metro-E connection should work just fine. You might run into processing overhead and throughput issues on the VPN Server but other than that it should be fine.
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Thu, 10/23/2008 - 04:00
  • Cisco Employee,
Eric,
Arul
