Reverse DNS Issue with Barracuda Spam Filter
Oct 23rd, 2008
Hi, I have a Barracuda Spam Filter which accepts our incoming smtp and passes it on to our Exchange Server.
For Outgoing emails the Exchange server sends directly out.
I have static Nats set up as follows (external IP's replaced)
Exchange Server
static (INSIDE,OUTSIDE) netmask
also access-lists as follows
Exchange (https & www for Outlook Web Access)
access-list OUTSIDEIN extended permit tcp any host eq https
access-list OUTSIDEIN extended permit tcp any host eq www
Barracuda (incoming SMTP)
access-list OUTSIDEIN extended permit tcp any host eq smtp
Problem is when I send emails out, it goes out as which does not match up with the MX record that points to
Therefore we are receiving Reverse DNS failures from recipients
<exchange1.ourdomain.local #5.7.1 smtp;550 5.7.1 Client host rejected: cannot find your hostname, []>
Is it possible for our Exchange Server to send out via ? (I cannot use the Barracuda as an outgoing relay)
shaw.chris Thu, 10/23/2008 - 04:41
Thanks Andrew,
Would I need this static NAT for the Exchange Server ( rather than the Barracuda as I want the Exchange server to go out as
I do have Global Nat set up using the Interface address for all inside hosts, but neither the Barracuda or Exchange Server use that address, they currently go out using the addresses I have set up in the Static NATs
