Network Connection Issue
Oct 23rd, 2008
Hi All,
When I connect my Laptop to Cisco 2960 switch port, It acquires IP address after 45-50 secs, sometimes it gets timed out.it dosen't happen when I connect to a nortel port.
Could anyone suggest what can be changed in the cisco switch configurations so that it decreases the connection time.
rmcarthur Thu, 10/23/2008 - 03:55
  • Bronze, 100 points or more
If you always use the same port to connect to the switch turn on portfast for that port.
Switch#spanning-tree portfast
That will cause the port to enter forwarding state immediately. The 45-50 secs delay you see is STP checking for loops before forwarding begins.
Use with caution though if anything other than a host device is likely to be connected.
Hope this helps, please rate if it does.
