Router 3825
Collin Clark Thu, 10/23/2008 - 03:59
  • Purple, 4500 points or more
The default username & password is cisco/cisco. Does that work?
Joseph W. Doherty Thu, 10/23/2008 - 04:53
Some the recent routers now come configured with a "one time" password. Unsure all the implications if you didn't reconfigure properly. If not, you may need to follow the password recovery procedure for the 3825. If your configuration is complex, once you break back into the router, you can grab the start-up config file from NVRAM.
