PIX v8.0 redundant-interface + 2600XM router
Answered Question
Oct 23rd, 2008
Hi all,
I plan to configure a PIX-515E running 8.0(3) with a Redundant outside interface (comprising of two physical Ethernet interfaces - active/standby), both connected to two ports on a 2611XM router. The PIX will be configured as such:
interface Redundant1
member-interface Ethernet0
member-interface Ethernet2
nameif outside
security-level 0
ip address xx.xx.xx.234 255.255.255.248
By doing this I wish to achieve interface controller (by distributing interfaces across multiple modules) and media redundancy.
I am struggling to comprehend how I should configure the interfaces on the 2611XM to work in this configuration.
The PIX will have a global IPv4 address assigned to the logical Redundant outside interface. The 2611XM presently has a single interface (Fa0/0) configured as follows (IPv4 address within the same globally assigned subnet as the PIX outside interface). The 2611XM has a Multilink PPP (multiple ADSL) connnection to the world.:
interface FastEthernet0/0
description "Link to PIX_outside"
ip address xx.xx.xx.233 255.255.255.248
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip virtual-reassembly max-reassemblies 64
ip route-cache flow
duplex full
speed 100
interface Multilink1
description "Face to world"
ip unnumbered FastEthernet0/0
Please can someone advise me as to how I should re-configure the 2611XM so that both physical interfaces (i.e. Fa0/0 and Fa1/0) are able to participate in a dual-link redundant configuration with the PIX.
Many thanks for your time and advice.
Overall Rating: 5 (1 ratings)
tomranson Fri, 10/24/2008 - 04:54
Hi Krisztian,
Thank you for your reply :-)
I had a feeling that bridging may be the way to achieve this, however I have not done this on a router before.
Given your advice, I believe that the following (straw-man) configuration on the router is what's required:
no ip address
no ip directed-broadcast
bridge-group 1
Interface FastEthernet1/0
no ip address
bridge-group 1
interface BVI1
ip unnumbered BVI1
bridge 1 protocol ieee
bridge 1 route ip
I will try this over the weekend and reply/rate accordingly :-)
tomranson Sun, 11/09/2008 - 07:24
Hi Krisztian,
I can confirm that the following configuration is fully functional.
Router:
bridge irb
ip unnumbered BVI1
ppp multilink
description Link to PIX515E-1 Ethernet4
no ip address
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
description Link to PIX515E-1 Ethernet5
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.20.1.1 255.255.255.252
bridge 1 route ip
PIX:
interface Ethernet4
description Link to C1841 Fa0/0
no nameif
no security-level
no ip address
interface Ethernet5
description Link to C1841 Fa0/1
no nameif
no security-level
no ip address
description Redundant link to C1841
member-interface Ethernet4
member-interface Ethernet5
nameif outside_redundant
security-level 0
ip address 172.20.1.2 255.255.255.252
All associated interfaces on both devices are physically up and the configuration is tolerant of physical media/transceiver failures.
I can manually change the active interface on the PIX with the following command:
# redundant-interface Redundant1 active-member [ Ethernet 4 | Ethernet 5 ]
Many thanks for your help with this.
Tom
