ACL problems
nickc1976
I have a Cisco 857 router.
I have given it a basic configuration and can now use it to get web access.
I want to allow incoming access to my network 192.168.2.0 from three external locations, and also to allow any outgoing connection
I have set up these access lists:
access-list 101 permit ip host 84.92.xxx.xxx any
access-list 101 permit tcp any 192.168.2.0 0.0.0.255 established
access-list 102 permit tcp 192.168.2.0 0.0.0.25 any
int dialer0
ip access-group 101 in
int vlan1
ip access-group 102 out
The problem is that 102 doesn't appear to be working, I can't use the internet on the local network. If I change 102 to:
access-list 102 permit ip any any
then I get internet access again.
show ip int for vlan1 shows the ip address as 192.168.2.1/24
Any suggestions??
22 Replies 22
Jon Marshall
Nick
Is this is a typo
ie. the mask is 0.0.0.25 rather than 0.0.0.255
Also are you changing the addressing because 192.168.2.0/24 is not routable on the internet so are you natting somewhere.
Jon
Hi Jon,
Thanks for the quick reply
Sorry, yes, that is a typo, the mask is 0.0.0.255.
Also, I do have NAT set up for 192.168.2.0/24. My internet access works fine, until I start adding ACL's
Nick
Nick
Apologies but this is where i'm getting confused ie.
this line is part of your inbound acl on dialer interface. But packets coming back would not be going to 192.168.2.0/24 - they would be coming back from the Internet to whatever you have Natted the 192.168.2.0/24 addresses to ?
So your acl should be
access-list 101 permit tcp any established
But you are saying this works without acl 102 ?
Am i making sense :)
Jon
Jon
I understand what you're saying - because of NAT, my returning packets won't have the destination address 192.168.2.0/24.
In my config, I have the following:
interface vlan1
ip nat inside
interface dialer0
ip nat outside
So I'm presuming my 192.168.2.0/24 address would be natted to my external IP provided by my isp - is that right? ie. 84.92.xxx.xxx
So I tried changing my acl to:
access-list 101 permit tcp any host 84.92.xxx.xxx established
but still I can't get an internet connection
Nick
Yes your acl 101 should refer to the natted address.
Also Giuseppe is right. Outbound packets on a vlan interface are packets going to machines on that vlan. Inbound packet on a vlan interface are packets coming from that vlan.
Don't think of inbound/outbound in terms of the machines think of it in terms of the interface.
Jon
Giuseppe Larosa
Hello Nick,
because ACL 102 is applied outbound should be
access-list 102 permit tcp any 192.168.2.0 0.0.0.255
from the point of view of internal Lan outbound traffic is directed to 192.168.2.0/24 not coming from it
Hope to help
Giuseppe
Giuseppe
I'm not sure I understand. 102 is being applied out of vlan1 or 192.168.2.1. So I would expect my source address for out going packets to be 192.168.2.0 0.0.0.255 and destination to be any
Hello Nick,
here it is the point:
packets that exit Vlan1 are directed to what ?
users in vlan1
think of a routed interface
int f0/0
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
this matches
try to use ip accounting output packets
a packet for 192.168.2.112 will exit this f0/0 and will have destination 192.168.2.112 not source 192.168.2.112
here Vlan1 is used to have a gateway for the few lan ports associated to L2 Vlan1 (like 877) but it is the same concept
to test do the following:
apply your ACL 102 inbound instead of outbound and verify if you can access internet
Hope to help
Giuseppe
Guys,
Thanks for your help so far. I understand what you are saying. I was looking at vlan1 in terms of the router rather than the interface.
I have changed my ACL's as follows:
access-list 101 permit ip host 84.92.xxx.xxx any (remote site IP)
access-list 101 permit tcp any host 84.92.xxx.xxx established (local site IP)
int dialer0
access-list 102 permit ip host 84.92.xxx.xxx any (local site IP)
int dialer0
access-list 103 permit ip 192.168.2.0 0.0.0.255 any
int vlan1
ip access-group 103 in
However, I still cannot get internet access when using a pc on the 192.168.2.0 network
Nick
Can you remove from your config
int dialer0
no ip access-group 102 out
and then let me know how you get on
Jon
Nick
Sorry i'm having a moment !!. PLEASE IGNORE THIS POST.
Jon
Right - lets start again :)
If you want to allow incoming access to network 192.168.2.0 do you mean connections initiated from outside. If so you need to use static NAT to setup a one-to-one translation for the 192.168.2.x hosts you want to give access to ie. you cannot rely on the dynamic NAT as you go out. It got a bit confusing because we kept using 84.92.xxx.xxx so lets use some dummy public IP addresses.
Outside interface of your router =
84.72.31.10
int dialer0
ip nat outside
int vlan 1
ip nat inside
So easy access-list first.
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
then you need to make sure all 192.168.2.x hosts are natted so
ip nat inside source list 103 interface dialer0 overload
the above allows all IP to be initiated from the 192.168.2.0 network to the internet and NAT's it to the outside interface.
Now for the harder bit
access-list 101 permit tcp any host 84.72.31.10 established
** this line allows return traffic for TCP connections to be allowed back in.
The established keyword only works for TCP so if you needed udp to be allowed back in then you need to add that in for each port you want eg.
access-list 101 permit udp any 84.72.31.10
Notice the way round this is. This is because the source UDP port coming back will the service and it will be in response to a connection initiated from inside eg.
if 192.168.2.15 initiates a DNS request to a DNS server then this will be allowed out because of acl 102 on vlan 1 interface. The destination port would be UDP 53 but the source port could be anything. When the packet returns the source port is now 53 because it is a response back from a DNS server.
Now the rest of your acl 101 is dependant what you want to give access to and how many spare public IP addresses you have. Lets say you have 1 spare public IP
84.72.31.11
and you wanted to give access to host 192.168.2.20 using http
you would need to add the following line to your config
ip nat inside source static 84.72.31.11 192.168.2.20
and then update your acl
access-list 101 permit tcp any host 84.72.31.11 eq www
Key thing is when traffic is initiated from 192.168.2.x network to internet you can hide all the 192.168.2.x addresses behind the one public IP of your outside interface. But when traffic is initiated from outside you need to tell the router which 192.168.2.x private IP the public IP is attached to.
Really sorry if i have confused you.
Jon
Thanks. I will go and test this and let you know how I get on.
I'll give you a bit more information about what I am trying to acheive.
The router is at a main office. There are two other offices that are permanently connected to the main office by IPsec VPN.
There is another office which occasionally connects to the main office via a VPN connection, then uses the software VNC to give remote support.
I don't mind what traffic is allowed out of the main office, but I want to restrict the incoming VPN so that only specified sites can make the connection.
Jon,
I'm having some problems still.
When should I apply this command:
I have tried
int vlan1
and I get a message saying 'Configuration failed'
