CUCM 6.1 and setting up Conference
Oct 23rd, 2008
When I want to setup a Conference with two Cisco 7941 devices then it works fine. But when I try to add a 3rd device to the Conference, I get an error and the connection is lost.
I hope someone can help me to sort out this issue.
Thanks.
Rob Huffman Thu, 10/23/2008 - 06:12
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sana,
What is the exact error message? Also, when you mention a Conference between two 7941's do you just mean a "call" betwen the two devices. Conferencing is not really invoked until you add the third party (and more from there)
Are you using the "built-in" CCM Software conference bridge?
Rob
ysanadiga01 Thu, 10/23/2008 - 06:42
Hi Rob,
Thanks for the reply.
We are using a "Built-in CCM" conference.
There is no error message on the screen but the users hear a tone.
User A and B are already talking. User A wants to add User C. At that moment they hear a tone and connection is broken.
Thanks.
Jaime Valencia Thu, 10/23/2008 - 06:51
  • Cisco Employee,
  • Hall of Fame,
    2011
check the codecs being used, SW CFB only supports G711
java
if this helps, please rate
