AP Power difference between WEP and WPA
Oct 23rd, 2008
  • Purple, 4500 points or more
Can someone tell me what to look for? I have two SSIDs on an AP: one is WEP and the other is WPA.
I have 5 bars on WEP ssid, but only 2 on the WPA side and eventually down to one.
John
talmadari Sat, 10/25/2008 - 14:37
Hi John,
Actually your are getting the same signal from both SSID's.
The reason that your are getting 5 bars in one and 2 in the other depands on the OS wireless uitlity.
If you will use a wireless sniffer you could see the RSSI reading in the frame header.
Cheers.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
