Catalyst console port hung
Oct 23rd, 2008
Somehow my console port is hung. When I telnet to the server and do a show user and I see the following for the console.
Line User Host(s) Idle Location
0 con 0 172.20.201.35 22:04:14
172.20.205.35 22:02:07
172.20.201.34 22:01:29
172.20.1.2 21:45:05
172.20.205.31 21:25:53
172.20.205.31 20:41:39
How do I clear the connections on the console so I can access again, without having to reload the sup.
MUHAMMAD SHAHEEN Thu, 10/23/2008 - 07:42
  • Silver, 250 points or more
the command is clear line vty x, where x is a number 0 to 15 for each session.
Hope this helps
Shaheen
rschwendeman Thu, 10/23/2008 - 07:53
these are not under the vty. all of these hosts are showing from the console. I had several ssh connections from the console and lost connection to the last device and now it is hung.
j.bourque Thu, 10/23/2008 - 11:17
What is the config under "line con 0"?
If you find a working solution please post.
Richard Burts Thu, 10/23/2008 - 11:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Robert
I wonder if it would work if you clear by absolute line number instead of by relative line number (line vty 0 is a relative number, line 0 is the absolute line number for the console). So I wonder if clear line 0 would resolve your problem.
Rick
pkaretnikov Mon, 10/27/2008 - 17:56
run a 'sh host', it should look something like this:
Host Port Flags Age Type Address(es)
R2 2002 (perm, OK) 2 IP 1.1.1.1
R4 2004 (perm, OK) ** IP 1.1.1.1
R6 2006 (perm, OK) ** IP 1.1.1.1
BB1-2 2007 (perm, OK) 2 IP 1.1.1.1
Frame 2008 (perm, OK) ** IP 1.1.1.1
cat3550 2009 (perm, OK) ** IP 1.1.1.1
cat3560a 2010 (perm, OK) 78 IP 1.1.1.1
cat3560b 2011 (perm, OK) 49 IP 1.1.1.1
R1 2001 (perm, OK) ** IP 1.1.1.1
R3 2003 (perm, OK) ** IP 1.1.1.1
R5 2005 (perm, OK) ** IP 1.1.1.1
use 'clear line x', where x is the last number(s) under port.
to clear my R1 I type 'clear line 1'
edit: basicly drop the first part, 2001 -> 1
Hope that helps.
peterbe Tue, 10/28/2008 - 19:32
Maybe try connecting to the console again and use 6 x to returned to the prompt. Then do:
show sessions
to get session number and use:
disconnect (may require 'ssh' option?)
to disconnect session(s).
