7600 PFC QoS - Policer question
Oct 23rd, 2008
Hi Sir,
I have a Cisco 7609 running IOS version 12.2(33)SRB3 with dual SUP720-3BXL.
Two devices are connected to ports Gi3/1 and Gi3/2. Both ports are in VLAN 901 and there's an SVI for VLAN 901. Module in slot 3 is WS-X6748-GE-TX.
I'm trying to rate limit traffic to/from both devices to 250Mbps. Below is my config:
policy-map POLICE_PSG
class class-default
police cir 250000000
conform-action transmit
exceed-action drop
interface GigabitEthernet3/1
switchport mode access
switchport access vlan 901
mls qos vlan-based
interface GigabitEthernet3/2
mls qos vlan-based
interface Vlan901
service-policy input POLICE_PSG
service-policy output POLICE_PSG
Can anyone comment if the above config meets the objective, especially on the inbound direction whereby I'm configuring VLAN-based QoS?
Thank you.
B.Rgds,
Lim TS
Giuseppe Larosa Fri, 10/24/2008 - 00:41
Hello Lim,
if you want to limit traffic to 250 Mbps bidirectional in the aggregate of ports 3/1 and 3/2 your configuration is fine.
If you want to limit to 250 Mbps bidirectional on g3/1 and 250 Mbps bidirectional on G3/2 your configuration does a different thing and you could only double the CIR rates but with no control on the single port.
egress policing is supported only at the vlan level.
The mls qos vlan-based instructs the switch to ignore the ingress policy-map applied to the L2 interface and to use the policy applied to the vlan.
see
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m2.html#wp1016198
Hope to help
Giuseppe
