IPSEC behind a PAT devices
Oct 23rd, 2008
Our firewall has multiple site-to-site VPN's as well as it supports Remote Access VPN (using an ASA). A number of RA users who are coming behind a PAT'd address are unable to VPN in, after doing some research I am seeing that a line needs to be added on both firewalls, ie:
isakmp nat-traversal 20
I fear though that this will "hurt" the site-to-site VPN based on this document:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/ike.pdf
section : Enabling IPsec over NAT-T
Is there any problem enabling this command on the firewall without harming any of the site-to-site VPN's or even RA VPN's?
ajagadee Thu, 10/23/2008 - 09:15
Roni,
You are on the right path, "isakmp nat-traversal" should overcome the issues you are running with RA Users through PAT Device.
And Technically, by enabling "isakmp nat-traversal", you should not run into any issues with L2L Tunnels. Atleast, that is what I have seen with Cisco VPN Servers. In case, if you have L2L Tunnels configured to third party vendors, I would recommend that you enable this command during a "Maintenance Window" and if possible, clear the isakmp and ipsec sa's, and re-establish the tunnels. So, you know for sure that enabling the command did not break the L2L Tunnel Configuration/behavior.
Arul
*Pls rate if it helps*
cisco24x7 Thu, 10/23/2008 - 15:50
If you are doing L2L VPN between Cisco and
and Checkpoint and/or Juniper devices, be
sure to enter this command as well:
no crypto ipsec nat-transparency udp-encapsulation
that will ensure the the L2L VPN to use ESP
instead of sending udp/4500.
