10-23-2008 08:03 AM - edited 03-10-2019 04:20 AM
Hi All,
I am trying to upgrade the AIP-SSM software from 5.x to 6.x , i dont know through which interface it contacts to TFTP server i.e external g0/0 or internal. It gives error of TFTP timeout and recovery is not completed. let me know how to upgrade or revert back to default.
10-23-2008 01:45 PM
If you have a working 5.x sensor that is reachable via the management interface (you can ssh or https into it), then you can use the upgrade ftp:// command.
But since you're mentioning TFTP, it sounds like you want to re-image, and not upgrade.
Installing the AIP-SSM system image
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliImage.html#wp1032373
10-24-2008 04:10 AM
yes i am trying to reimage the AIP-SSM-10 module and tried with the hw-module module 1 recover configure command. Please tell where should i connect the TFTP server i.e G0/0 port or ?
10-24-2008 02:26 PM
The AIP-SSM10 module has a management port on the module (it is the only external interface on the module). Connect this to the network that can reach your TFTP server.
10-27-2008 03:15 AM
Thanks, it worked and i have upgraded the image to 6.x
