10-23-2008 08:53 AM - edited 03-15-2019 02:08 PM
Is there a way to turn on detailed phone logging so I can see what a phone is doing and what keys are pressed? If so, how do I do it and how do I view the log?
Thanks.
Solved! Go to Solution.
10-23-2008 09:18 AM
yes, a CUCM detailed trace can give you those details. not what the phone is doing but what keys are pressed and states like going on-hook, off-hook, etc
java
if this helps, please rate
10-23-2008 09:18 AM
java
