Stack 3750
Answered Question
Oct 23rd, 2008
hello, i have a problem , i have a stack of switchs 3750-24ts,3750-48ts and i want to add and 3750G-48PS switch to the stack,but When i connect the sw 3750g-48ps to the stack of switchs working those switchs block their console port and do not permit input any command and can't form part of the stack of switchs already working. the IOS version in the switchs of the stack is c3750-ipbase-mz.122-25.SEB2 and the IOS version on the new switchs tryng to be part of the stack is c3750-ipbase-mz.122-35.SE5
Correct Answer by glen.grant about 8 years 5 months ago
If you look in the logs you will probably see a version mismatch . You should be able to copy from the stackmaster into the new switch flash and then just reload the slot , if not then downgrade the new switch to match the rest of the stack . Always make sure that the new switch is off before connecting and inserting the switch into the stack.
Overall Rating: 4 (2 ratings)
Joseph W. Doherty Thu, 10/23/2008 - 16:39
Suggest you insure both stack and switch to be added have same version (and ideally feature set) installed. I.e. either upgrade the stack first or downgrade the switch to be added.
Correct Answer
glen.grant Fri, 10/24/2008 - 01:37
  • Purple, 4500 points or more
