1120 802.11b radios and WPA
Oct 23rd, 2008
Can anyone confirm that an 1120 series with an 802.11b only radio can do WPA. This unit is EOL and I can only find specs for a 802.11g unit.
If so what is there a recommended IOS level?
thanks
jeff.kish Thu, 10/23/2008 - 13:55
  • Silver, 250 points or more
Unfortunately, Cisco 802.11b radios do not support WPA-AES. Since it's an 1120, you also cannot upgrade the access point, so it seems you're stuck without it.
Now, it should be able to do WPA-TKIP, and upgrading to the newest version of code should do the trick. I'm not sure what version started supporting it, though.
dunay Thu, 10/23/2008 - 15:33
I assumed it should do WPA and not WPA2 I just can't find valid confirmation on this.
thanks
MATTHEW BALYUZI Fri, 10/24/2008 - 06:33
The 802.11b radio can only do WPA as it has no AES support on the radio module.
There was an upgrade kit to support 802.11g, this does do WPA2/AES as well as multiple BSSIDs.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
