NIC Teaming
dvanzee
Level 2
Level 2
Can someone tell me if NIC Teaming is supported with CM 4.2.3?
Brandon Buffin
Yes, it is, assuming it is supported with by your server and OS version. See Step 7 and the associated link in the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/4_2/cm423ins.html#wp473584
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin
Brandon
ONLY supported on HP servers
java
if this helps, please rate
java
Thanks!
