How many simultaneous VPN connecitons...
Answered Question
Oct 23rd, 2008
How many simultaneous VPN connections can you have utilizing the ASA-5510? Will using a NAC affect this number? Thanks in advance.
Correct Answer by ajagadee about 8 years 8 months ago
Bill,
The below data sheet for the ASA has the information that you are looking for.
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
IPsec VPN Peers - 250
SSL VPN Peer License Levels* - 10, 25, 50, 100, or 250
Also, it is my understanding that using NAC should not affect the above numbers.
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Thu, 10/23/2008 - 11:23
  • Cisco Employee,
Bill,
Arul
