Lab scenerios for testing
Oct 23rd, 2008
I am setting up a CCNP lab at home, and was looking for some test scenerios. Where they give you what they want the outcome to be. Then after you build it, the paper shows you the configs that "should" have been put on the boxes. Does anyone know of a place to get this sort of item?
lffrwatson Tue, 10/28/2008 - 07:14
I'm sure there are workbooks out there for this. I use ipexpert a lot but I believe its only for CCIE prep. Why not take your gear and draw a sample topology and build it and see what happens. If you run into issues then ask on here. I would focus on the routing protocols maybe build a lab with OSPF running or EIGRP. Play with access-lists, and NAT. Set up a DHCP server on router. Play with static routes and adjust routing metrics etc. The skys the limit.
