Connection speed over POE
Oct 23rd, 2008
Can someone confirm for me that using a POE adapter is has a limitation of 100Mbps? I have a AIR-PWRINJ4 and after troubleshooting have determined that I get 1000Mbps connection speed on my 1250 AP until I use it with the POE adapter.
MATTHEW BALYUZI Fri, 10/24/2008 - 06:50
No, it should work at Gig. Our one here certainly is.
Check the patch leads are all properly seated.
Trending Topics - Security & Network
