UPC 7.0 - System status msg's
Oct 23rd, 2008
I cannot figure out why my Voicemail option shows "Failed to connect- Server Unreachable" when I can connect to Unity7.0 just fine and ping from my laptop that runs UPC. I login with the same ID/pswd on the Accounts/Preferences - Voice Messaging location. I have RTP'd to Unity and logged in successfully with the same ID/pswd combo. Any other ideas? Thanks.
mserwon Thu, 11/06/2008 - 17:20
Have you set up the mailstore on the Presence server?
j.mccartney Fri, 11/07/2008 - 06:09
I don't think it was setup, I'm new to Presence and wasn't here for the install. How do you check/setup mailsotre?
Thanks for the help. - John
