Aironet client - Problem with LEAP and PGP whole disk encryption
Oct 23rd, 2008
Implementing PGP whole disk encryption of laptops with Aironet CB21AG nics and LEAP configuration. Configured to pass login (AD) credentials from PGP login thru to Windows.
Will not pass thru AD credentials at login until LEAP config removed.
Has anyone seen this issue?
hadbou Fri, 10/31/2008 - 12:04
Check for the LEAP profile configured for the username password and other parameters as an error in configuration might result in the issue you are facing.It will be easier to troubleshoot the issue if the error message you obtain during the process is provided.Check the Error messages present in the troubleshooting guide present in the following url so that you will be able to find the error related to LEAP with the solution for the same:
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
