10-23-2008 03:53 PM - edited 03-06-2019 02:07 AM
I have a 3560 Layer3 switch with two VLANs. VLAN10 IP address 192.168.1.1 and VLAN 20 IP address 10.10.10.1
I have most of my clients and file server on VLAN 20. I am able to map the drive to server without any issue. However I have a few client on VLAN 10 they are not able to map to the file server. I can ping the server IP no issues. How can I get VLAN 10 to access the file server?
10-23-2008 03:57 PM
How are you resolving the server ie. WINS, Active directory ?
If you try from a DOS prompt on a client on vlan 10
net use * \\
what happens ?
Jon
10-23-2008 04:02 PM
I get error message " Network Path Not Found"
The weird thing is. If I take a client that is on VLAN 20 I can map over the my other server on VLAN 10. At IP address 10.10.10.5
10-23-2008 04:08 PM
Could you post config of switch.
Also how are the clients resolving the server name - which OS are the clients running ?
Jon
10-23-2008 05:30 PM
10-24-2008 04:29 AM
on vlan 20 interface you have the ip address 10.0.0.1 ?? what does it mean. your comp have the ip address range 10.10.10.x
rate if it helps
10-24-2008 05:31 AM
Sorry, I sent the old config. All the same except the IP address scheme.
interface Vlan10
description Mgmt VLAN
ip helper-address 10.10.10.5
ip authentication mode eigrp 100 md5
ip authentication key-chain eigrp 100
eigrp100
standby 10 ip 192.168.1.254
standby 10 preempt
interface Vlan20
description Client PCs
ip address 10.10.10.1 255.255.255.0
ip authentication key-chain eigrp 100 eigrp100
standby 20 ip 10.10.10.254
standby 20 preempt
router eigrp 100
network 10.10.10.0 0.0.0.255
network 192.168.1.0 0.0.0.255
no auto-summary
10-24-2008 05:36 AM
I think think that you have also to enable WINS if you have also DNS inside your net
10-24-2008 07:16 AM
Thanks to all that helped.
I have found the issue IT is not with my VLAN or Routing. The Microsoft server had routing turned on. I disabled routing on the server and I am able to connect just fine.
