Warning message
Migration from UCM 3.x to 6.x
Oct 23rd, 2008
My company is migrating from call manager 3.1, I am doing a clean install of UCM 6.1 on a new server. Is there a way to use an upgrade tool transfer phone licenses from version 3 to 6? Or do I have to buy new phone licenses?
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 10/23/2008 - 16:53
  • Cisco Employee,
  • Hall of Fame,
    2011
get in touch with licensing at [email protected] and they will send you a spreadsheet you need to fill in so they can generate your license.
it has been posted around before so if you search netpro you can find it (though anyway you will need to contact licensing and the spreadsheet needs to match the version you're going to)
java
if this helps, please rate
Rob Huffman Fri, 10/24/2008 - 04:55
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeremy,
Just to build on the great info from Java, your investment in IP Phone licenses will carry over fully so no further $$ will be involved. Here is the Calculation tool (attached)
Hope this helps!
Rob
