Call subflow
Hello I need to know how to do debug in a call subflow it have variable within of script main. the call subflow receive a one variable of script main.
how do I am able to debugear the callsubflow without running the main scrip?
BCOLE2007
Hi Santiago,
If the Subflow doen't have any media steps, you can just run it as 'Active Debug', and populate the variable that is passed into it based on what the Main script is passing.
If the subflow does have media steps, then you will need to make this subflow be able to stand on its own and assign it to an applicaiton and put a boolean variable, such as IsParentScript, default this to True. However whenever the Main script calls the subflow it passess a False to the IsParentScript variable. Now use the IsParentScript varible to control whether the Accept Contact and other passed variables are turned on or not and whether the terminate is to occur and so forth. Again you could also control and dummy values in that are passed from the Main script.
two things I find real handy are to to an log to and external database, if that fails send myself emails with the variables, such as error conditions
Hope this helps.
*Please rate all posts
Blair
BCOLE2007
Hi Santiago,
Hope this helps.
Blair
