satish_zanjurne Thu, 10/23/2008 - 23:26
  • Silver, 250 points or more
I assume grouping means , you are talking about port-channel or Etherchannel L2 or L3.
Refer Below link for understanding
http://cisco.com/en/US/tech/tk389/tk213/technologies_white_paper09186a0080092944.shtml
For configuration refer below links
http://cisco.com/en/US/tech/tk389/tk213/tech_configuration_examples_list.html
HTH..rate if helpful..
usmanjathol Fri, 10/24/2008 - 04:33
not grouping.. and other device is non cisco.. and dosent support it
glen.grant Fri, 10/24/2008 - 03:14
  • Purple, 4500 points or more
You would have to explain this better 2 fastethernets and a gig port ??? If you only have a single gig link between switches then there is no way to etherchannel that link . If thats not what you mean please explain.
usmanjathol Fri, 10/24/2008 - 04:27
i have a switch which i want to connect to a router. both are 1000 meter apart.. connect them on fiber.
router has a SFP port and module.
switch has all 24 FE ports.
i also have a FE to Fiber converter having 2 FE ports and 1 Fiber port. the converter is manage able so i can put both FEs on converter in one VLAN... how can i use 2 switch ports so i can get atleast 200 Mbps
